Old 18 Aug 2011, 07:41 pm
Morkeste Morkeste is offline
Default Re: 07 - rear dorrs wont open from inside - child locks are off
There is a plastic piece that connects from the handle to the bar that goes across the door panel. Something may be wrong with that or it might have popped off (since it is just clipped in)
There are a few screws holding the door panel on and then some clips. You can gently pry it off with your hands like I did, or you can get a set of plastic interior panel removers. Either way, that will take off your panel and you will be able to further investigate the root of the problem.. Should take about 10 min to remove it.
Also, when you do get the panel loose, remember that the handle still is (or should) be connected to that bar via the clip, so be careful with it.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49
