Old 03 Sep 2012, 02:18 pm
oscar_the_grouch oscar_the_grouch is offline
Default Re: 2001 PT Cruiser won't start. No Spark
Ok,....i replaced the crank sensor and still nothing. upon closer inspection i found the plug to the crank sensor had been rewired (spliced) at some point. i lost the wire when it went through the firewall,........but i found a broken wire in the iring harness,.........so i spliced the new one that was there into the broken one in the harness and the car fired right up.
I still have a heavy miss at idle but i will look into that later,......and it is throwing a code for the MAP sensor and when driving it cuts out at 3500 RPMS,.......no big deal,.....i will get to that tomorrow.
I want to Thank You very much for the help. I really do appreciate it.
Rob S.
East Brady,PA
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49
