Old 03 Sep 2012, 10:10 pm
pluminator pluminator is offline
Default Re: 2001 PT Cruiser won't start. No Spark
Originally Posted by oscar_the_grouch View Post
Ok,....i replaced the crank sensor and still nothing. upon closer inspection i found the plug to the crank sensor had been rewired (spliced) at some point. i lost the wire when it went through the firewall,........but i found a broken wire in the iring harness,.........so i spliced the new one that was there into the broken one in the harness and the car fired right up.
I still have a heavy miss at idle but i will look into that later,......and it is throwing a code for the MAP sensor and when driving it cuts out at 3500 RPMS,.......no big deal,.....i will get to that tomorrow.
I want to Thank You very much for the help. I really do appreciate it.
Rob S.
East Brady,PA
certainly another lose or non connected wiring if its cutting at 3500. Its supposed to do that in park :-D to prevent over revving, if its doing it while driving the vehicle thinks its in park :-D check all the grounds.
just for giggles heat test the CAT with a laser. If its hotter at the front, than the back, its toast which could also cause the vehicle to cutt out around that RPM. Especially if you had a cracked manifold, that usually only happens with a massive overheat, which could be caused by a Converter :-D
