Old 10 May 2013, 07:31 am
CREWZIN CREWZIN is offline
Default Re: 2008 PT Cruiser says key is in ignition Help!
NO, it's not common at all. First make sure your engine battery is fully charged and the connections aren't corroded. A weak battery causes havoc on the electrical system. Second, it sounds like the ignition lock might be causing the problems (if it's not the battery). Many owners have had to replace it.
