Old 15 Jul 2013, 08:56 pm
Busted_PT Busted_PT is offline
Default Re: REBUILDING THE TURBO!!!!
Time to put the peaces together.
First get the shaft ready to go in by installing the oil seal. All metal to metal and rubber seals need lubed with assembly lube as you install each part.
Now install the bearing on the exhaust end of the center section.
Time to install the shaft and shield.
Press in until fully seated.
Turn it around and begin assemble the intake side. Installing the bearing and spacer.
The trust washer. the notch for the oil passage goes to the inside or face down.
Now the oil seal and deflector.
Now inswtall the oil seal and deflector into the cover.
Make sure the oil ring is pushed back into the cover. Not exposed like in the picture. Install the rubber seal and push the cover down into the hole of the center section. until the grove for the snap ring is visible.
Install the snap ring.
Put the impeller onto the shaft and tighten the nut to 100 in lbs. If I'm correct.
