Old 15 Jul 2013, 08:57 pm
Busted_PT Busted_PT is offline
Default Re: REBUILDING THE TURBO!!!!
Put the outer rubber seal on and install into the outer housing.
Line up the pin and hole for proper seating.
You can see the pin shining in the hole to confirm proper alignment.
Next the snap ring.
Then the adapter for the oil line. Then all done.
You are ready to install on the PT. Don't forget the spacer ring, between the exhaust manifold and the turbo. For more installation tips chick my page in the projects section. Also a little reminder from my friend mole.
Make sure to prime the turbo well before you start the car up.
Pull the fuel pump relay, disable the ignition, and hold down on the gas pedal (to the floor)
try to start the car but it wont start. Do this for 10 seconds. make sure to keep the gas pedal floored.
then do it again for 15 seconds. Watch for the oil light on the dash to go away. then its ok to start the car (well if everything else is good)
