Thread: Battery Cables
Old 17 Jul 2014, 01:46 pm
pasadenahotrod03Dreamer pasadenahotrod03Dreamer is offline
Default Re: Battery Cables
You can remove the cable harness from your car and "build" a new and better one from heavier gauge cables bought at your local auto parts store. You can get new block and starter end terminals and new battery terminal ends which can be soldered together with the cables. Make the new cable an inch or so longer than the old ones so when needed you can replace the terminal ends.
