Old 17 Sep 2015, 05:52 pm
Handy_Cruiser's Avatar
Handy_Cruiser Handy_Cruiser is offline
Default Re: LCA vertical bolt (pain in the nut ;-) & Right Center Engine Mount
If I remember right, the bolts are 13 mm. And you may be able to reach at least some of the bolts with the boxed end of and end wrench without have to remove anything other than the splash shield.
In the photo below of my PT, you can see two of the bolts from the top. I believe I could access these and possibly the other bolts from beneath the car by simply remove the splash shield. I might have to do it from the wheel well and reach around and up past the sub-frame blind and without line of sight. But I've removed bolts in far worse places. An extra long end wrench and/or a curved wrench might help. A crow's foot might work too if the attached bar has a low enough profile.
It's worth a try if you think the bolts are stuck.
