Thread: Code P1776
Old 10 Mar 2016, 08:55 pm
CREWZIN CREWZIN is offline
Default Re: Code P1776
Here's the TSB....
MIL Illumination - DTC P1776 Solenoid Switch Valve Latched in LR Position
MODELS:
2004 (AN) Dakota
2004 - 2005 (CS) Pacifica
2003 - 2004 (JR) Sebring Convertible/Sebring Sedan/Stratus Sedan
2003 - 2004 (KJ) Liberty
2003 - 2004 (KJ) Cherokee (International Markets)
2002 - 2004 (LH) 300M/Concorde/Intrepid
2003 - 2004 (PL) Neon/SX 2.0
2003 - 2005 (PT) PT Cruiser
2003 - 2005 (RG) Chrysler Voyager (International Markets)
2003 - 2005 (RS) Town & Country/Voyager/Caravan
2003 - 2004 (TJ) Wrangler
NOTE: Refer to the following table for specific applications.
Model Engine Transmission
AN 3.7L 42RLE
CS 3.5L 41TE
JR 2.4L or 2.7L 41TE
KJ 3.7L 42RLE
LH 2.7L or 3.5L 42LE
PL 2.0L 41TE
PT 2.0L or 2.4L 41TE
NUMBER: 21-001-13
GROUP: Transmission and
Transfer Case
DATE: January 31, 2013
RS/RG 2.4L, 3.3L or 3.8L 41TE
TJ 4.0L 42RLE
DISCUSSION:
If the vehicle operator describes a MIL illumination and the technician finds DTC P1776
Solenoid Switch Valve Latched in LR Position is set, the DRBIIIŽ can be used to access
the event data screen and look at the “TRS Code” reading.
NOTE: The solenoid switch valve is located in the valve body and NOT in the
solenoid pack.
TRS Code Reads TR2
If the “TRS Code” displays “TR2” it is an indication that the manual valve was not fully in
the OD position at the time the DTC was set. Check the shifter cable adjustment and
adjust if necessary. Also check the shift control system for excessive friction and/or routing
issues.
TRS Code Reads OD
If the “TRS Code” displays “OD” then a sticky solenoid switch valve is the primary cause.
Perform the proper diagnosis for the valve body. Inspect for foreign material in the solenoid
switch valve and plugs.
POLICY:
Information
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49
