Thread: Code P1776
Old 10 Mar 2016, 11:34 pm
ptcruisersteve ptcruisersteve is offline
Default Re: Code P1776
P1776 - Solenoid switch valve stuck in L/R position
Possible causes and solutions:
1. Torn sealing ring on OD accumulator piston due to poor machining of bore
Repair accumulator bore and replaced sealing rings
2. Possible shift cable adjustment or failed pressure switch
Check shift cable adjustment & solenoid pack build date.
3. Sticking solenoid switch valve
Free up stuck valves in valve body
4. Failed L/R pressure switch
Replace the solenoid pack
