Thread: RPM moving
Old 21 Apr 2016, 09:49 am
2step's Avatar
2step 2step is offline
Default Re: RPM moving
I do see the one little drop in RPM at 44sec but the rest of the small changes of 10 RPM or less seems normal to me. A vac leak would send the RPM up fairly high and I don't see that. What I do see is a short drag on the engine like maybe the alternator or other accessory momentarily shifting modes. Even worn torque strut bushings could cause that. I'm not sure if I could actually hear the engine slow in the video.
At this point, I wouldn't worry too much about it unless it is a chronic problem all the time, cold engine right after start up, warm engine waiting at a stop light, in gear, in neutral, etc.
