Old 18 May 2016, 08:00 pm
LionPT's Avatar
LionPT LionPT is offline
Default Re: Help! Need advise please
Originally Posted by Chrissy78 View Post
I am getting 3 codes now since the switch has been changed p0457 p0456 and p0572
P0456: EVAP
P0457: EVAP
P0572: Brake Switch 1 Stuck On
When the brake pedal is depressed, the stop light switch sends a signal to the Engine Control Module (ECM). When the ECM receives this signal, it cancels the cruise control.
All 3 codes could be from a bad vacuum hose. I suggest checking all the vacuum lines especially to & from the cruise control.
P0456/0457 could also be a bad gas cap.
