Old 18 May 2016, 09:37 pm
ptcruisersteve ptcruisersteve is offline
Default Re: Help! Need advise please
Originally Posted by Chrissy78 View Post
P0572 was the original code.
P0572 = Brake Switch Circuit Low Conditions:
Possible Causes:
1. Intermittent condition Fused B+ circuit problem
2. Brake switch sense circuit is shorted to ground
3. Brake switch is closed
4. PCM has failed
Was the installation instructions followed when replacing the brake switch?
