Old 24 Oct 2016, 08:07 pm
_PTGT03's Avatar
_PTGT03 _PTGT03 is offline
Default Re: GT Turbo P0335 intermittent failure
This is obviously your crankshaft circuit that is opening and causing the car to shut off. In fact one of my last cars I designed a circuit to open the crankshaft position sensor to shut the engine off at a stop to save fuel.
You should inspect the harness from the sensor back about two feet and check for corrosion, baked insulation, damage, and backed out terminals. you can get a good replacement from the wreckers and cut out the bad section and solder in or crimp in a replacement.
