Old 26 Apr 2017, 07:02 pm
rckstein's Avatar
rckstein rckstein is offline
Default Re: OEM radio choices?
Welcome to the forum
It doesn't really matter what was available as stock if you are going to replace it, does it? Looking at the MyGig info, what makes them so special that you would pick one of those? There are numerous other double din stereos to choose from and several threads on this forum of members that have installed them.
http://www.ptcruiserlinks.com/forum/...e-install.html
https://www.infotainment.com/blogs/n...dios-explained
https://www.amazon.com/Chrysler-Navi...n+center+bezel
What you will have to be concerned with is you will need to replace the center bezel with a double din one. And when installing the stereo, depending on the unit you choose, you may have to modify or completely remove the center shelf in the dash that the stock stereo sits on.
Please go to the Welcome New PT Cruiser members section, introduce yourself and tell us about your PT
