Old 03 Dec 2017, 06:48 pm
ptcruisersteve ptcruisersteve is offline
Default Re: 2001 PT Limited Auto Transmission - Error Codes p1684 and p0700 went into limp mo
Originally Posted by katydidindeed View Post
I have a 2001 PT Limited that I love and to keep it decided to replace its' transmission back in 11/2012. It has been great since. I don't drive that often, once or twice a week on local jaunts, so it sits idle most of the time. I replaced the battery 08/16 with the least expensive model from Walmart (due to budget constraints). The battery has a 1 year guarantee. Last week when I went for a short trip, the car went into limp mode and the check engine light came on less than 1/2 a mile from home, so I turned around and came back. Checked the codes - P1684 and P0700. Later that day I started searching for ideas as to what the problem might be and finally decided to add some ATF+4 fluid to see if that would fix it. The existing fluid was still nice and red and clean, but it was a little low, so I added about 1/3 of a quart. Then I took a short trip to check if that helped... no limp mode and the transmission worked fine. I was going to take it to the shop a few days later just to confirm, but the next day I had to take another short trip to the grocer and when I started the car to go back home, the check engine light had disappeared. So I checked the codes and they were gone as well. While I do think the additional fluid was necessary, I am curious if the battery may be losing steam and triggered an issue with the TCM that caused a false positive and forced the limp mode. The battery alert has not been coming on to indicate an issue, but since I drive so infrequently, I was trying to figure out why the P1684 code. Thoughts?! Regardless, my 17 yr old car is still chugging away and I'd like to keep it that way. If I should get a better battery let me know. Thanks, this forum has saved me a bunch of money and kept my PT Cruising!
P1684 indicates that the PCM memory has been cleared within the last 50 ignition cycles. I would recommend cleaning the battery posts and battery cables to make sure you have good contact. See if P0700 code comes back after doing this.
If after you reset the codes and clean the battery posts and cables the P0700 code comes back the best thing to do is to take the Pt Cruiser to a transmission shop where they will give you the actual transmission codes being triggered for free. P0700 is just a generic code for the transmission stating there might be something wrong.
