Old 03 Dec 2017, 10:08 pm
oldthom's Avatar
oldthom oldthom is offline
Default Re: 2001 PT Limited Auto Transmission - Error Codes p1684 and p0700 went into limp mo
Also, here is something to think about. If you are just using your PT for occasional short runs it might not ever get out of the cold start mode. Which is a richer mixture of gas which leads to a build up of carbon on pistons, valves and plugs. The car needs to get out there amongst them now and again, it needs to warm up and run with the big dogs as they say. Makes it run better and most likely last longer.... Just saying......
2004 LE 64K
