  #14 (permalink)
Old 25 Jan 2018, 05:54 pm
My02RedRide's Avatar
My02RedRide My02RedRide is offline
Default Re: 2006 - 2010 Double Din Pioneer Install
No picts at this time for the camera install but it isn't that difficult. Mounted mine in the pocket for the license plate LIGHT. 2 main leads from the camera. The red one gets tied into the LEFT tail lamp REVERSE / BACK UP WIRE. From there I ran the YELLOW camera output lead under the left sill trim all the way up to the dash top area then down to the radio pocket. Like I said, there is a lot of room with the dash top panel removed to run wires. Since you tapped into the reverse back up light there is no need to connect a hot lead at the radio. You make that connection in the PAC harness with the green wire for Reverse Sense (follow the PAC instructions).
2002 PT 4 door Inferno Red
2008 PT Convertible Bright Silver
