Old 18 May 2018, 11:19 am
rob302's Avatar
rob302 rob302 is offline
Default Re: Tips/advice building first motor in garage
feeler gauges
red and green plastigage
those are bare minimum what you need for measuring clearances
antisieze and assembly lube should be on hand and considered tools, because if you don't have them you won't use them.
get a REAL ring compressor. -> https://www.summitracing.com/parts/w...8750/overview/
do not my any means even look at the corrugated band type they sell at local parts stores. this is something i learned the hard way. i broke a ring and had to buy another set for $120. my friend called me a dipshit. i said "here you try it" and his ring broke too. the style i linked to you can push the piston in with your thumbs using very little effort. no adjusting, no tapping, no hammering, no breaking stuff.
and the books.
