Old 03 Jul 2018, 11:35 pm
dsab dsab is offline
Default Re: aftermarket radio
If the ground is good it sounds like it is a power issue. check your power wires again. There are sometimes two wires that supply power to the radio. One is power from the battery and the other supplies power to the switch. Make sure these are both connected.
Another thought. Does the radio have a fused line? If so when you installed the radio did you have the battery disconnected? If not you may have accidentally blown the fuse
2002 Limited Edition 2.4 Auto with 177k Miles
