Old 04 Jul 2018, 03:10 am
KalebSikora's Avatar
KalebSikora KalebSikora is offline
Default Re: aftermarket radio
Originally Posted by markeele View Post
I am trying to put an aftermarket radio in the pt. I bought the wiring harness adaptor plug wired same colors together and when i plug it in the unit wont power on. Is there something im missing the oe unit is the standard 1 disc unit i would think it should work. Anyone have any tips or experience with this? Its a 2007, sorry if this has been asked and answered before. I couldnt do a search on my tablet for some reason
On the harness you need to match up all the wires correctly. The OEM wires should say what they are. You need to crimp them together accordingly. I'm assuming if you did all that correctly it's possible that you forgot to connect the remote turn on. The PT doesn't have this wire from factory, so you have to tap into the accessory wire and connect that to the blue wire with the white strip (also known as the remote turn on wire) on the harness you bought.
This accessory wire connects to the front cigarette lighter in front of the shifter. You don't need to remove the whole center console to tap into that wire. I personally used a t-tap and ran that wire to the remote turn on wire on the harness. If you don't know what t-taps are or where to get them, this is an example of the same t-taps I used. They work great.
Here is an example of my car where I t-tapped into that wire:
