Old 24 Jul 2018, 11:37 pm
ptcruisersteve ptcruisersteve is offline
Default Re: 2008 PT Cruiser says key is in ignition Help!
Originally Posted by Nevermore673 View Post
Hi, I am having the exact same issue. It is not the battery or lock cylinder, as I have replaced them both. What else could be the problem?
Have you checked to see if the pin is broken between the actuator and the lock cylinder? If the pin is okay then I suggest you check the actuator.
