Old 21 Aug 2018, 08:49 pm
RickinPA RickinPA is offline
Default Re: 2008 PT Cruiser says key is in ignition Help!
The ignition lock will have a switch to sense when the key is in the ignition. This sense switch has likely became jammed in the "key in" position. Looking at a 2004 Neon service manual, I see a "KEY-IN IGNITION SWITCH SENSE" terminal on the ignition switch connector.
You could try cycling the key in & out.
You could try using a little lock lubricant (use a lubricant specifically for locks and use it sparingly).
