Old 12 Nov 2018, 06:32 pm
rsrocket1's Avatar
rsrocket1 rsrocket1 is offline
Default Re: Biggest Mistake of My Life
When I did the timing belt on my 08 Subaru Outback I removed the alternator just to find an anchor point for a socket wrench I used to hold and accessory belt when I needed to remove the harmonic balancer. There wasn't enough room to fit my impact wrench onto the crankshaft bolt and I didn't want to risk doing the breaker bar and starter "bump" so I simply wrapped the drive belt over the harmonic balancer and used the socket wrench to anchor it. There was a convenient shelf behind the alternator so I took it off to fit the wrench.
Removing the alternator was literally a 5 minute job and a couple of bolts. Of course a head gasket job on a boxer engine is completely different and I had to take that into a shop to have it done.
I've been looking at the alternator job on the PT and am keeping my fingers crossed and hoping it will hold up and not need to be replaced for a long time.
