Old 15 Jun 2019, 03:47 am
myckee myckee is offline
Default Re: Will this computer work with my PT GT
Originally Posted by NitroPT View Post
Mykee is very knowledgeable about PT's ECU's
Mykee has shown that he will stand behind any ECU he sells as a working unit!
Mykee does not program ECU's himself (that I am aware of to date?) for customers,(unless he has now purchased the software and the tool needed to do it which I have not read anywhere that he has?) sends them to someone that does window sales and installation for a primary living and as a sell learned side business ECU programming.
The only guarantee to these mildly programmed ECU's is that they will work . They are a very close program to a Chrysler STAGE 1 last known update before they were discontinued? A custom ECU programming requires several adjustments and monitoring of the engine vital information one of which and most important is the AFR's.
Actually I do all the programming myself and have never shipped my units to anyone for programming...with the exception of a couple of PCM years ago to Sykes for Stage programming. That experience is what prompted me to learn how to do it myself. ��
I can erase and reprogram any factory pcm with any factory programming that will be compatible with the hardware.
I even have most of the "factory" Stage 1 (and some srt4 Stage 2) tunes for the various years and models.
I have the capability of doing custom tunes, but as I do not believe my proficiency is at a high enough standard, I do not offer this to anyone.
As far as the manual 07 year goes, regardless of whether the car is turbo or not, they used the same hardware in all of the manual cars. This is actually true from 04 and up. All are turbo programming compatible, and all are therefore stage 1+ compatible.
If you are going to buy one on eBay, get one from a manual, non-turbo, 07 car as it will have not been cooked to death already by the heat coming off the turbo.
