Old 16 Jul 2019, 06:10 pm
partyd partyd is offline
Send a message via Yahoo to partyd
Default Re: 2008 PT Cruiser says key is in ignition Help!
There is a small long Plastic pin in the ignition cylinder, this pushes into the electronics part of the ignition switch, this is your key sense, most people damage the plastic pin when they are replacing the electric part of the ignition solution replace the pin or cut the key sense wire,
your remote its not working because it believe that the key are in the ignition
2008 Pt cruiser Touring
2004 Pt Cruiser GT
2004 Chrysler 300M
2008 Chrysler Pacifica awd
