Old 28 Aug 2019, 06:19 pm
soonercruiser's Avatar
soonercruiser soonercruiser is offline
Default Re: Quality of Rear Oval Window Manfacturers
THANKS AGAIN TO ptprice FOR THE POINTERS!
If nothing else, the suggestions he made, made me slow down and think a little about the options to save that $300 aftermarket window skin!
So, after some honey-dos today, I took another look at it.
Again....I LOVE MY DREMMEL TOOL!
I started by making a line with the edge of some masking tape about where I guessed it would take to reduce the edge of the Eurethane window cover for me to be able to open the rear hatch. (I hadn't used it in days)
Then I started by using a diamond wheel to cut straight down thru the cover, as there was a good 1/4 inch or more free space where the mounting tape was.
After that first cut, I had the wifie hold the hatch open as I took a picture of the window cover as it passed near the top of the car. STILL TOO CLOSE!
So, I took off some more - more so in the middle 1/3 of the hatch....and then thinned the edge downwards.
So after I rechecked the clearance again , I took a photo to send Doug at Willpak Industries to prove that it WAS NOT FAILURE OF THE MOUNTING TAPE!
IT WAS EXCESSIVE WARPAGE OF THEIR PRODUCT that caused the interference.
As ptprice suggested, next will be a thin decorative metal strip retained by metal screws into the OEM metal hatch.
I have ordered some butyl rubber rope to put under the edge of it to be sure there won't be excessive water getting under it.
The nice thin strip of aluminum I have now, has a little lip curling back downwards, so the leading edge will not be obtrusive.
Funny thing is, even now, unless you are up close, and on the side of the car, you don't even see the mess I already made.
Frank, aka SOONERCRUISER,
