Old 01 Jan 2021, 07:24 pm
ptcruisersteve ptcruisersteve is offline
Default Re: P0133 and P02096 Engine Codes
I would suggest removing the triggered engine codes and see if the same codes come back with an OBDII Scanner tool.
P0133 -O2 (B1 S1) Slow Response
Possible Causes:
1. Exhaust leak present in the exhaust manifold or exhaust pipes
2. O2 element is fuel contaminated
3. O2 element is deteriorated or it has failed
P2096 - Downstream Fuel System 1/2 Lean Conditions:
Possible Causes:
1. Exhaust leak
2. Engine mechanical problem
3. O2 Sensor has failed
4. O2 Sensor signal circuit or return circuit problem
5. Fuel contamination
Your 02 sensor might be triggering P2096.
I would suggest checking for exhaust leaks first then check the wires going to the 02 sensor.
If okay I would check for engine mechanical problems. You might have something causing the 02 sensor to trigger.
Do you have a turbo on your 2005 Pt Cruiser? If so they are known to have cracked exhaust manifolds.
