Old 14 Jan 2021, 05:53 pm
ptcruisersteve ptcruisersteve is offline
Default Re: Typical TPS range ? - 2005 non-turbo - 210k mi
This was mentioned by another member. Hope this helps you.
First is, the PCM has 2 timers. Throttle time and Exhaust time. Both count up and down from 0 minutes to 5 minutes. And they both need to be over 2 and half minutes before the system will even attempt to run monitors.
They are not visible in any OBD scanner or data list. Only in the factory DRBiii scanner and even then only in a special OBD monitor section under the pretest section for the monitor you are testing.
So how do you get them to count? The throttle timer counts up when the throttle is open and counts down when it is closed. The exhaust timer counts up when the vehicle is in motion and counts down when it is stopped. The secret is that neither will start counting until the PCM sees wide open throttle, at least 85%.
These timers can be found on all Chrysler’s from 1998 to mid-2006. Some only have 1 timer, most PT’s have both. I’ve seen cars with aftermarket floor mats that keep the gas pedal for reaching that 85% threshold. I’ve also seen defective throttle position sensors and vehicle speed sensors that keep the timers from counting. But you can monitor those inputs with most OBD scan tools.
I know this is referring to a turbo.
On the 2.4 turbo engines I’ve seen where the Cam Timing for the Exhaust Camshaft is off a half a tooth or more and that keeps the engine load just out of the required range run the full Catalyst monitor. It will only run the Fast Pass and not set the monitor to complete. It will not set a check engine light either as the Exhaust Cam is not monitored, only the Intake Cam. Also the timing belt needs to be tight and have no play in it. Some of the aftermarket belts will stretch after they run in and that pulls it out timing just enough to not run the monitor.
