Old 19 Jan 2021, 06:07 am
MPT MPT is offline
Default Re: Typical TPS range ? - 2005 non-turbo - 210k mi
Over the weekend we got 3 TPS sensors of 2005 and later vintage from a salvage yard 35 min away. The resistance values are slightly different than mine yet none helped; the voltage and min-max throttle % are same as before with my original sensor. And, there's nothing obvious that is amiss so-far with the throttle body or cabling, etc..
So I'm beginning to wonder if the sensor and throttle body are “as-designed??”
I have a neighbor and a distant friend with a Cruiser so maybe I’ll see if I can check if their throttle performance is any different…
Apart from that, maybe I’ll just change the timing belt (and make sure that other things that can affect timing-mismatch are not factors… such as the camshaft to sprocket alignment dowel pins being not sheared or damaged, etc).
MPT
Silver 2005 Touring ATX , non-turbo, 211K mi (so-far!) - our family is first owner
Western NY - Rochester Buffalo Area
Many needed repairs / worth it / kinda fun... includes control arm, steering rack & K-frame member {each at a different time-!} - self and with local friendly mechanic.
Most notable mod is installing an AirLift(tm) Kit inside the rear springs (for the Boat / trailer !)...
