Old 24 Feb 2021, 08:05 am
frankbiganski frankbiganski is offline
Default Oil Light Comes On Only When Stopped
I have a 2006 PT Cruiser Turbo with over 108k miles. I've replaced many, many parts on this beauty over the decades and it still runs strong!
But recently, the oil light will come on when I'm stopped and the chime goes ding, ding, ding, real fast. As I start to go, the light goes off and the chiming stops.
Oil is good and new, and I'm not getting any error codes either.
Do you think it's a good start to begin with replacing the oil pressure sensor?
I have a new TIPM, clock spring, radiator, timing belt, head gasket, shocks, struts, bearings, and just about everything BUT, I don't have any record of replacing the oil pressure sensor. At least this will be a lot less expensive than replacing the oil pump, but I believe the oil pump is original as well.
Thanks for your replies as always!
Frank
