Whats everyone doing about cloudy headlights?????
Like Tree18Likes
  #91 (permalink)
Old 14 Aug 2014, 10:10 pm
Default Re: Whats everyone doing about cloudy headlights?????
Originally Posted by turbo1013 View Post
mine is the by far easy but the most room, for error
rag
go jo pumic hand cleaner or such,
brake clean
shoot brake cleaner on the rag and wipe quickly
on to the light being carefull to not let it turn soft,
then using other rag
wipe up with pumice hand cleaner
mine just need the insides done,, but out indes are easy 2 times a year by that method,
Mine is Much much easier buy a can of clear spray enamel can and spray your headlights lightly or until you see a good clear Headlight
  #92 (permalink)
Old 12 Nov 2014, 02:55 pm
for now I just don't drive at night ....lol
cruserdad1976 likes this.
first 4 cylinder,it sure aint no 8....2004 2.4 base pt 5 speed manual.live wires,screeming demon coil, stage 1jet chip,strut tower bar,airraid setup..nothing fancy...NO TURBO
  #93 (permalink)
Old 12 Nov 2014, 04:21 pm
That is better than braille driving....
rcktpwrd likes this.
  #94 (permalink)
Old 12 Nov 2014, 09:37 pm
its def on the list ..but a purge valve is first in line most likely...then i will read and do whats most recommended...I am amazed they are even glazed still..my car was either covered or under cover without sunlight even hitting front end ....it never sat in sunlight for long.. its was a backup car most of its life,, I had several daily drivers...used it mainly for long distance trips with my old dog...
  #95 (permalink)
Old 30 Nov 2014, 07:28 pm
podo2000's Avatar
http://www.ptcruiserlinks.com/forum/...cture5340.html
http://www.ptcruiserlinks.com/forum/...cture5338.html
http://www.ptcruiserlinks.com/forum/...cture5339.html
http://www.ptcruiserlinks.com/forum/...cture5337.html
Bit of 600, 1000 and 2000 wet/dry. Going to do again and clearcoat tomorrow
2004 PTGT 135Kmiles
  #96 (permalink)
Old 30 Nov 2014, 07:35 pm
If your clearing you need not to go so smooth. Just Either 600 or the other and shoot the clear. Make sure it's one of those really crystal clear coats you see these days. You can sand and buff the clear if you put several coats on.
podo2000 likes this.
  #97 (permalink)
Old 30 Nov 2014, 08:54 pm
podo2000's Avatar
Thanks busted - will look around for a good clear UV resistant buzz can tomorrow.
2004 PTGT 135Kmiles
  #98 (permalink)
Old 09 Jan 2015, 11:04 am
Croiser's Avatar
Some polishing of headlights done today. The passenger headlights looks fine after 10 minutes of polishing with Colgate MaxWhite, but the driver headlights has some bad looking smudge on the inside.
Toothpaste, cheap but really effective way to do it, at least for a while.
2002 2.2 CRD Limited
  #99 (permalink)
Old 09 Jan 2015, 03:08 pm
That blotch looks like it ate into the lens - doesn't look like it's inside.
I bet wet sanding will remove it. Or try claybar.
  #100 (permalink)
Old 09 Jan 2015, 09:19 pm
soonercruiser's Avatar
Cool Re: Whats everyone doing about cloudy headlights?????
Yes! There are tons of historical threads on this.
Search this "Detail" forum.
Frank, aka SOONERCRUISER,
Horn and headlights problem ducerman Tech & Performance Forum 6 18 Dec 2007 10:24 pm
cloudy headlights prettybluewoody Exterior Accessories Forum 2 24 Sep 2007 12:46 pm
Don't Buy eBay Headlights sakigt General PT Cruiser Discussions 8 05 Apr 2006 03:18 pm
Anyone have problems with Headlights? Ginger Tech & Performance Forum 8 01 Jun 2005 07:11 pm
spray-on-tint on headlights? JoePT Exterior Accessories Forum 7 20 Jul 2004 04:58 pm
