Would this welder work on repairs on the body and frame work on pt cruiser?
Like Tree11Likes
Old 22 Mar 2015, 11:40 am
Smile Would this welder work on repairs on the body and frame work on pt cruiser?
I hope I'm posting in the right section but I'm wondering if this welder I found on Amazon could work for body work and frame repairs on the pt cruiser or any other car to? Could someone give me suggestions on this welder or post one that you recommend hopefully at a fair price some where's. Thanks guys.
http://www.amazon.com/gp/aw/d/B003FG...mEL&ref=plSrch
Old 22 Mar 2015, 12:31 pm
Default Re: Would this welder work on repairs on the body and frame work on pt cruiser?
It says:
"max metal thickness: 18 gauge / 3/16-Inch"
Old 22 Mar 2015, 12:46 pm
Specifications: thermal overload protection amps: 80 (max 125), duty cycle 20-percent at80 amps, wire size: .030 - .035,
Nothing I would want to do any real work on a vehicle body with.
These are great for quick fixes that do not require but a minute or so of welding.
Old 22 Mar 2015, 12:56 pm
you might check out the ones on eastwood. they start pretty cheap and i've never heard anybody complain about one.
Eastwood -MIG Welder | MIG Welders | MIG Welding Cart | MIG Welding Machine & Accessories
you really would be better off getting one that uses gas instead of flux. you'll have less spatter and no slag to deal with. cleaning off the slag is a pain in the rear and it gets old very quickly.
left is mig with gas, right is mig with flux:
you can weld with that but there is no temp adjustment and only lets you adjust the wire speed. so if it's designed to weld up to 3/16" thick, you may find yourself burning holes on the thin metal of the car. if you're hell-bent on using that particular welder, you can prevent the holes by clamping a brass plate on the back of the thin steel while you weld. it will help with the burn through and won't stick to what you're welding.
you's be lightyears ahead at least upgrading to a welder like this: MIG Welder | MIG Welders | MIG Welding
it has 2 dials so you can control the temperature and wire speed, and will weld up to 1/4". additionally, the one i posted will let you use gas or flux, so if you get sick of cleaning off the dirty welds shown on the right, you can hook a tank up and make clean welds like you see on the left. cleaning welds sucks. you get pinholes in the welds and you end up poking at them with dental picks so you can weld over the pinhole again. if you didnt get it clean enough, you'll be going over it a third time. i can't stress enough how annoying it is. it's a huge time waster.
on the other hand, my friend tom has a flux core welder (but with 2 dials) and seems to do OK with it. he made this forge using flux core. the welds are not pretty, but it got the job done. he's been welding with it for years and even with all the practice he's had, i wouldn't want welds like that on my car.
File Type: jpg 460683_10151464690407677_2142501679_o.jpg (82.2 KB, 50 views)
Handy_Cruiser likes this.
Old 22 Mar 2015, 01:03 pm
also just an FYI that welder you posted is also $184 from home depot. the amazon "SAVE $150" thing is BS
Old 22 Mar 2015, 03:51 pm
Hey rob I could have used the brass trick when I was doing some welding some time back. Your a man of many talents.
Old 22 Mar 2015, 04:55 pm
Thats how i felt.
a retired welding teacher/welder fixer guy told me about that when i was telling him about all the holes i burned through my car
Old 22 Mar 2015, 05:00 pm
Originally Posted by rob342 View Post
Thats how i felt.
Been there done that.
Old 22 Mar 2015, 06:23 pm
I did not know that Home Depot sold that one for the same price I will have to keep a closer eye from now on when I'm researching that stuff. Thanks for the heads up and thanks again for all of your information and I will be searching that site you gave me and find a better one that offers more I'll just have to save more money before I can get one but that's fine I don't need one right away I was just getting information together for when I start looking more closer into it for which one I wanted. Thanks again for all the help.
Old 22 Mar 2015, 06:46 pm
One more question that's been bothering me and I wanted to ask someone that's been welding allot before, Can welding cause eye damage with the more welding you do and even if you're wearing the welding shield every time you weld?? Just curious to know I've been wanting to ask someone that.
5-speed throttle body work on auto pt? shelbyzman Tech & Performance Forum 2 03 Aug 2013 07:16 am
will this throttle body work on my 04 pt? auction ends in two hours shelbyzman Tech & Performance Forum 5 31 May 2013 10:06 am
The PT Cruiser is a "work of art"... Gary04GT General PT Cruiser Discussions 4 20 Apr 2005 09:31 pm
convert into a work cruiser rexdean Exterior & Interior Styling 1 09 Oct 2003 01:01 pm
ARRRG..Help...anybody know about body work? Cal Cruzer General PT Cruiser Discussions 5 23 Jul 2003 04:18 pm
