Go Back   PT Cruiser Forum > Regional Forums > Europe PT Forum
2003 PT Cruiser Limited Edition with start-up problems
Like Tree2Likes
  #11 (permalink)
Old 27 Mar 2014, 03:31 am
DieselPunk's Avatar
Default Re: 2003 PT Cruiser Limited Edition with start-up problems
Sounds like the battery - mine does this on rare occasions after a cold night and needs a jump start direct to the battery from another running vehicle. Give that a try.
2002 2.2 CRD Limited Diesel Panelvan Conversion "Love and Thunder"
  #12 (permalink)
Old 27 Mar 2014, 01:08 pm
Thanks for all your advice, certainly giving evrything the once over is going to help. As i stated earlier the previous owners have left the cruiser in a poor state, so yeah i have to clean up connections and make them tight. Having said that I have made a bit of progress ..
If i almost push the clutch pedal through the floor the engine cranks. Though it sounds like its searching for fuel even though i have half a tank. Yes i hear the pump on key turn.
The weather isn't kind today, rain lashing down. I have a booster charger on charge ready for a renewed attempt tomorrow.
I love the feel of my Cruiser, even though it doesn't work
  #13 (permalink)
Old 20 Jun 2014, 08:25 am
Thumbs up Re: 2003 PT Cruiser Limited Edition with start-up problems
update.. hope this helps future cruisers who may, like me, over look the obvious or succumb to the fear that something drastic is wrong. ...
I called out for help on a more local forum, suggestions were that I should call out a well known auto sparky ....
The first thing i did was to charge up the booster battery and sit the cruisers battery on a trickle charge overnight.
When the sparky arrived, obviously he wanted to hear what happened on turn of the key. He then pulled the plugs and laffed.... " these look as if they haven't been changed since the car was born" .. I could almost park my van in the gap !!!
the plug gap was huge, therefore the spark was weak. explanation was that constantly trying to turn the engine on a weak spark, the fuel pump was simply flooding the engine.
20 later, armed with a new set of plugs the only thing left to do was remove the pump relay, turn the key and effectively "dry out" the engine.
Relay back in situ and ...... My ltd edit fired up !
Yayy.. I took it for its M.O.T the only thing questionable on its roadworthiness was the anti- rollbar bushes, which I had renewed.
Success, we're back on the road.
Thanks everyone for your input
  #14 (permalink)
Old 20 Jun 2014, 08:39 am
Hope you replaced the plug wires (leads) as well - they age as well and weaken the spark.
  #15 (permalink)
Old 20 Jun 2014, 08:50 am
yes but I'd love some blue ones .. .. do u know of a cruiser specialist who revels in pimping up PT's
  #16 (permalink)
Old 20 Jun 2014, 09:49 am
Buy some wire loom - It's plastic tubing in different sizes and colors (colours), split on the side, you place it over wires and tubing to add color.
http://www.rakuten.com/prod/taylor-3...gawb2L0XuMcGbP
Tags
2003, codes, electrics, faults, ignition
2003 pt cruiser limited edition problem kenny08vt Tech & Performance Forum 5 21 May 2013 06:11 pm
2003 PT Limited Edition No Start No Power Nada ChaseUtoo Tech & Performance Forum 9 24 Mar 2012 04:52 pm
02' PT Cruiser Limited Edition Fire & Transmission Problems.. Help?? ssccrab PT Cruiser News and Rumors 2 01 Feb 2012 03:26 pm
Just got a new 2003 limited edition pt cruiser Tyler General PT Cruiser Discussions 9 18 Feb 2011 01:07 am
2003 Chrysler PT Cruiser Limited Edition (brentwood / oakley) $11000 skylight craigslist 0 12 Jul 2007 09:46 pm
