Go Back   PT Cruiser Forum > PTCruiserLinks.com > Feedback and Support
Coolant problems
Old 22 Oct 2016, 01:06 pm
Default Coolant problems
2003 turbo, runs fine, stays at running temp, here's what a got, after it is parked for about 3 hours it has a coolant spit under the right tire, let the car sit for more the 2 days and the radiator will still have pressure in it, new cap 18 lbs.new water pump and belt.
Old 22 Oct 2016, 01:13 pm
Default Re: Coolant problems
Tell us a little more about you and your car for proper introduction to the forum..
After your next trip, when the car is hot, check the little bleeder on the thermostat housing and closely check the black rubber tubing that runs between the neck of the radiator fill and the over flow tank for cracks or leaks.
Welcome to the forum.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 22 Oct 2016, 01:16 pm
I would suggest checking the little hose that goes from the radiator cap to the overflow reservoir tank.
Also check the thermostat housing. It's a common problem with PT Cruisers.
I see that JoeX posted similar suggestions as I was typing.
Leaking coolant - "Engine coolant pipes"? xkey General PT Cruiser Discussions 3 01 Jun 2014 09:11 am
Troubleshoot coolant leak: Photo of Coolant on top of engine radiator cap MarcusO Tech & Performance Forum 7 27 Apr 2013 09:16 am
coolant problems im stumped backyard_bandit Tech & Performance Forum 4 23 Mar 2012 03:53 pm
coolant sensor circuit problems swordfish Tech & Performance Forum 1 15 Apr 2010 12:11 am
Coolant Problems? KingKole02 Tech & Performance Forum 7 22 Nov 2005 02:27 pm
