Hot exhaust, melted EGR valve, no exhaust restriction
Old 07 Mar 2011, 03:40 am
Default Hot exhaust, melted EGR valve, no exhaust restriction
Hi,
My first post here. Be gentle.
My friend's 2001 PT Cruiser keeps melting EGR valves. The exhaust air is hot. No exhaust restriction, catalytic converter is fine, same problem even with catalytic converter unplugged. The mechanic is at a loss about what the problem could be.
FYI: Tropical climate, as my username implies, around 90F every day.
Any suggestions? No engine codes, other than a very recent P1193 (IAT Circuit High) which is probably unrelated and came after the EGR problems (and maybe from when the engine was worked on to replace the last EGR valve).
Many many thanks.
Old 07 Mar 2011, 01:44 pm
UptownSport's Avatar
Default Re: Hot exhaust, melted EGR valve, no exhaust restriction
I'd guess the valve is being held open for some reason-
It's probably not designed for constant, full flow.
The IAT is then getting TOASTED by the exhaust flow.
I doubt the exhaust is getting too hot.
Why? No idea.
install a restrictor until you figure it out
Tags
egr 2001 exhaust hot
Melted fuse scares me HELP! invidious Tech & Performance Forum 1 24 May 2009 05:08 pm
WTT: My dual exhaust for your stock exhaust Dirk_Gently Classifieds: For Sale/Trade 5 01 Oct 2008 03:27 pm
3'' exhaust JaviPTGT Turbo Performance 9 28 Feb 2008 10:04 pm
exhaust for the PT outfit Tech & Performance Forum 7 19 Feb 2008 11:56 pm
Mopar/Borla Exhaust and Center Exit Exhaust? blueberrygt Turbo Performance 2 07 Jun 2006 07:44 pm
