Replacing LCAs - Two questions
Old 19 Dec 2011, 11:27 pm
Default Replacing LCAs - Two questions
80K miles and a torn ball joint boot, so figure I'll put in two Moog LCAs this week. Two questions:
  • Do I need to have it aligned after this, if I don't touch the tie rods?
  • How do I check for wear on the INNER tie rods?
It currently tracks straight, with no shakes or shimmies. I do occasionally get a popping noise from the right front on washboard surfaces. This is the side with the torn boot. Sway bar bushings look a little tired, so I'm replacing those, as well.
'02 Limited, stock except for K&N and modified airbox, Crane FireWires
'06 Magnum SRT8, a few mods
Old 19 Dec 2011, 11:36 pm
Default Re: Replacing LCAs - Two questions
Is good to have an alignment if you haven't done it in a while but like you said, you are not touching the tie rods. The inner tie rods you can check them by lifting one wheel and move it in and out to "feel" any play.
Old 20 Dec 2011, 10:37 am
UptownSport's Avatar
You might consider replacing the outers if you haven't already.
Old 20 Dec 2011, 11:10 am
The inner is a ball joint so with one tire in the air and the other on the ground, visually watch the outer for play as you move the tire. Any side-side movement at all of the tire indicates a worn inner (provided the outer isn't visually moving either. A wheel bearing would have play all the way around.
Old 20 Dec 2011, 01:58 pm
Sweet... that's the info I was looking for. Thanks!
Old 07 Jan 2012, 10:04 am
compdr59's Avatar
The wheel alignment is a must. I thought I could hold off after replacing my control arm bushings and a wheel bearing. The car drove straight, but it drifted while highway cruising. After the alignment, I felt a huge difference.
Original Owner 135k
replacing TCM Bentron General PT Cruiser Discussions 15 19 Jun 2011 03:17 pm
Replacing CV boot, how does this this come out? jere Wheels, Tires, Suspension 0 30 May 2010 02:14 pm
replacing Cat omaolain General PT Cruiser Discussions 7 05 May 2010 08:27 pm
Some questions on replacing a coil in a 2002 PT Cruiser mbellofatto Tech & Performance Forum 4 25 Mar 2009 07:44 am
Questions Questions..newbie DaShado PT Cruiser Convertible Forum 0 01 Apr 2006 12:22 am
