Bang, rough ride, small oil leak idles fine
Old 20 Dec 2011, 09:50 am
Default Bang, rough ride, small oil leak idles fine
K so otw to work this am something happened. Felt like a pothole then a horrible banging like a flat tire, but when I let off the gas it cleared up. Hit the gas, pounding, let off, ok. Pull over and find a dollar bill size oil spot dripping. It slowed and stopped. Get car on jack to peek and find oil all over steering boot and belts and lca.
Noticed main big honking motor mount bolt is plain gone! Engine still in car held up by torque struts.
Is that motor mount bolt seal an oil passage? I peeked in the hole with a light and the motors shifted forward so I'm looking at the flat of the engine side.
Any other thoughts on source of oil leak?
Old 20 Dec 2011, 11:16 am
cruserdad1976's Avatar
Default Re: Bang, rough ride, small oil leak idles fine
dont knwo buit i dont think it is realted to the motor mount being borke
Old 20 Dec 2011, 12:31 pm
Engine mount bolt has sheared cleanly and the motor dropped an inch. I'm guessing the oil came through the crank seal (tho that was rpl at 93k (27k ago)). Undoubtedly the motor bucked around causing the banging.
Now, how the hell am I going to get this massive bolt out to put a new one in? Its flush at the removable part of that mount but holy crap that was a pain when I did the timing belt.
Old 20 Dec 2011, 01:41 pm
Wow...looks like you are going to have to remove that big iron bracket again, in order to remove that broken bolt.
idles rough edscrz General PT Cruiser Discussions 6 10 Nov 2010 06:31 pm
after timing belt idles rough dpmeeks Tech & Performance Forum 7 21 May 2009 06:00 pm
05 pt cruiser idles rough and stalls at idle wncengine Tech & Performance Forum 0 08 May 2009 10:31 am
ODD BANG?? mjb457 Tech & Performance Forum 3 06 Jul 2007 04:48 pm
What's the Best Bang for my Buck? Gunner Turbo Performance 30 07 May 2005 02:49 pm
