P0300 Random Missfire
  • 1 Post By soyomb
Old 19 Jul 2012, 04:03 pm
Default P0300 Random Missfire
I've been reading here when I've had problems with my pt. I just had the P0300 code and I read previous posts and I tried everything but like everybody else the problem never went away for good. I took it to a few shops and they all said that I needed the heads worked on . I had just done that and could not believe that. Just wanna share my experience and hope you guys can benefit from it. I took the valve cover off and turn the engine on and I noticed that the shaft was only moving on one side. It turned out to be broken . After wasting all the money in plugs, wires,coil packs all kinda of censors, etc,etc, I had to buy the shaft , replaced it and the car is running like never before.
Old 19 Jul 2012, 05:25 pm
Default Re: P0300 Random Missfire
well, plugs, wires and sensors are definitely not a waste as they do need replacing on occassion. the coil probably was, tho, as they rarely go bad.-
glad to see you finally got it fixed. we all know how frustrating it can be trying to diagnose problems.
Metro77279 likes this.
Old 19 Jul 2012, 05:47 pm
UptownSport's Avatar
WOW! Usually this is from installing a severely warped head that someone just milled- Cam journals are then not straight-
Oil comes up driver's rear, but last place that gets oil (due to internal routing) is driver's rear
So if it gets dry this is area that will suffer most
Crazy missfire ! ptTurbo528 Tech & Performance Forum 7 24 Jan 2013 10:32 am
# 1 missfire bompa45 Tech & Performance Forum 3 03 Jun 2012 10:44 pm
05 pt intermitant missfire bobrat Tech & Performance Forum 3 19 Aug 2011 10:10 pm
error code ques-... got a p0300- random misfire... batta Tech & Performance Forum 4 18 Apr 2010 03:26 pm
Missfire & backfires Turbo Red General Turbo Discussions 6 18 Oct 2004 07:58 pm
