Buying a 2006 Chrysler PT Cruiser Touring - What to look for?
Like Tree2Likes
  • 2 Post By soonercruiser
Old 12 Jun 2014, 07:59 am
Question Buying a 2006 Chrysler PT Cruiser Touring - What to look for?
Hello, I am buying a 2006 Chrysler PT Cruiser Touring with 98,000 miles on it from an acquaintance. It has the 2.4L 150 hp I4 with a 4-speed automatic tranny. The previous owner was very good at maintaining the vehicle (all the service records) and the car is very clean both inside and out.
My question is, is there any particular issues that i should look for that are unique to the PT Cruiser line, especially the 2006, other than the normal mechanical issues that one looks at when buying a pre-owned vehicle? Thanks
Old 12 Jun 2014, 08:19 am
Default Re: Buying a 2006 Chrysler PT Cruiser Touring - What to look for?
I own an 06. Check for front end trouble. rocker arms and tie rods. The front end seems to always take a beating on these cars.
Old 12 Jun 2014, 08:34 am
The one thing I always tell people to do when looking for a used PT is to have it idle for about 15 minutes with the A/C turned on HIGH. Watch the temp gauge to make sure it doesn't go above half way and it should continue to give cold air inside the cabin. IF the gauge starts to climb towards the red, the car has problems. It might be as simple as a new thermostat or as bad as a head gasket.
...and like every other used car, turn on everything (lights, radio, have someone look at the brake lights when the pedal is down, front and back windshield wipers etc. Take it for a test drive, fast/slow and hit the brakes hard to see if it stops in a straight line.
Old 12 Jun 2014, 09:21 am
cruserdad1976's Avatar
at 98000 i hope some one has done the timing belt water pump and tensioners cause if not there is around $1200 other than that what has been said remember its a 8 year old car with miles on it
Old 12 Jun 2014, 09:25 am
As others have said - suspension and timing belt.
Look over those service records - look for timing belt replacement and a flush of the transmission.
Follow Crewzin's advice and let it idle w/A/C on.
Good luck.
Old 12 Jun 2014, 10:09 am
VNT's Avatar
VNT VNT is offline
If they have maintenance records look for in 98K
1) a couple of services on the transmission fluid and filters
2) 3-4 changes of plugs and 1-2 sets of wires
3) 2-3 Changes of the coolant
4) replacement of LCA or LCA Bushings
5) Tires and alignements
6) Timing Belt and water pump, tensioners etc
7) multiple oil changes
8) Upper and lower radiator hoses and heater hoses
9) 1-2 Brake jobs including new rotors and pads
10) Replacement of PCV a couple of times.
If unsure have a mechanic check it out and as noted on the cooling, the fan operation.
VNT
00 Durango SLT+ 5.9 4x4
02 Grand Cherokee 4.7 4x4
05 PT GT Silver 5 Spd Conv
17 Challenger SRT A8 GoMango
18 JL Wrangler Sahara Punkn
Old 12 Jun 2014, 10:20 am
LionPT's Avatar
Also do the key dance:
To do the key dance, turn everything in the car off, no stereo, wipers, lights, etc., just to keep the system load down. Turn your key to the accessory position, that is two clicks prior to the start. So, you have Off, Acc, On, and Start (which is the spring-loaded position). Turn to Acc, wait a few seconds, then On, Acc, On, Acc, and On... leave it in the On position (NOT THE MOTOR START POSITION!), you should see a series of dashes ------ at your Odometer, while the PT runs the internal diagnostics testing. Takes maybe 10 to 15 seconds or so and then it will return the DTC's (diagnostic trouble codes).
Than download the Diagnostic Trouble Codes.pdf from http://www.ptcruiserlinks.com/forum/...s-library.html
Old 12 Jun 2014, 07:56 pm
soonercruiser's Avatar
Cool Re: Buying a 2006 Chrysler PT Cruiser Touring - What to look for?
THIS^^^^^
If the timing belt, water pump and tensioners have not been changed, offer $800-1,000 less.
Frank, aka SOONERCRUISER,
Old 14 Jun 2014, 08:09 pm
harrym's Avatar
Originally Posted by soonercruiser View Post
THIS^^^^^
Good advice!
Harry
2005 Touring n/a - Cool Vanilla with J&J vertical billet grille, PTeazer tail lights, Chrome wheels and Baby Moons.
Tags
2006 pt cruiser, new buy
2006 CHRYSLER PT CRUISER TOURING **ONLY 5,900 MILES** 28 MPG** (fairfield / vacaville skylight craigslist 0 15 Jul 2007 02:00 pm
2006 CHRYSLER PT CRUISER TOURING **ONLY 5,900 MILES** 28 MPG** (fairfield / vacaville skylight craigslist 0 14 Jul 2007 12:20 pm
2006 CHRYSLER PT CRUISER TOURING **ONLY 5,900 MILES** 28 MPG** (fairfield / vacaville skylight craigslist 0 12 Jul 2007 03:20 pm
2006 Chrysler PT CRUISER TOURING (san jose) $12988 skylight craigslist 0 09 Jul 2007 05:24 pm
2006 CHRYSLER PT CRUISER TOURING **ONLY 5,900 MILES** 28 MPG** (fairfield / vacaville skylight craigslist 0 07 Jul 2007 06:56 pm
