Waterless coolant?
Old 14 Feb 2015, 12:33 am
rockandroller's Avatar
Default Waterless coolant?
Anybody here using this in their PTs?? ( I just found out I can get it wholesale...) :-)
High Performance Coolant Evans Cooling
2004 'Turbo Lite'
Old 14 Feb 2015, 12:35 am
Default Re: Waterless coolant?
I have not but it does sound cool.
2005 Purple Pt Touring 130k Still Running Strong
New timing belt and water pump at 130k.
Old 14 Feb 2015, 12:43 am
What is it's thermal conductivity?
What is it's viscosity? (does it put a heavier load on "water" pump?)
How much does it cost?
Old 14 Feb 2015, 11:09 am
I understand it has a lot of advantages but is expensive. For normal use not really needed. More of a racing thing.
I one warning on this stuff you have to make sure there is NO water in your system.
Also if you're trying to fix a problem FIX THE PROBLEM first!
Mike
Old 14 Feb 2015, 12:43 pm
So basically no one has mentioned useing it on this forum yet and
some are not correctly reading the technicall information about the use of it?
Old 15 Feb 2015, 11:18 am
I have seen it demonstrated a number of time on video one from a manufacture and that is where I got my info. Not worth much but more useful that nothing. Using something does not make one you an expert.
You're the expert so what say you?
Respectfully,
Mike
Old 15 Feb 2015, 11:29 am
I saw a demo and physically touch it . RPW a Wholsale distributor carries it but even at my cost I never could justify trying it.
The one problem is for maximum Benifits the cooling suystem should be flushed and chemically cleaned . Then the system really should be air dried which takes several days to a week in many applications. You could get a couple gallons of 90% isopropyl run it through the sytem to speed the dring process.
If you read the technical info you could have 3% by capacity of water in a system and it would still acording to that ife work?
That is the extent of my input at this time about it?
We learn the text and then practice the lessens to become experenced!
Landing a plane on simulation is always very different in the phisical world.
Old 15 Feb 2015, 11:43 am
the track by me has a big issue with coolant and wants us to run straight water because coolant is so hard to clean up. they may or may not have a problem with this stuff. if i was the tech inspector, i'd be more likely to make the car use water as that would be easier than researching this stuff.
i'd guess "almost, but not quite as good as water?"
Old 15 Feb 2015, 12:32 pm
LionPT's Avatar
What happens if you blow a hose or some other leak, you can't just add water to get back home. Your gonna have to carry a least 2 gallons of the stuff with you at all times.
GrapeApe likes this.
Old 15 Feb 2015, 12:36 pm
You can add water I a case like you di scribed acording to the technical information on thier site?
Air in Coolant. euphonium_john Tech & Performance Forum 32 07 Jun 2014 03:21 am
Leaking coolant - "Engine coolant pipes"? xkey General PT Cruiser Discussions 3 01 Jun 2014 09:11 am
coolant fan anybody theboogmobile Turbo Performance 4 04 Jun 2013 01:37 pm
Troubleshoot coolant leak: Photo of Coolant on top of engine radiator cap MarcusO Tech & Performance Forum 7 27 Apr 2013 09:16 am
Coolant help. pt4cec General PT Cruiser Discussions 9 15 Sep 2009 08:28 am
