Need a recommendation to add Keyless Entry to Gen 2 PT
Like Tree3Likes
  #11 (permalink)
Old 03 May 2017, 08:28 am
LionPT's Avatar
Default Re: Need a recommendation to add Keyless Entry to Gen 2 PT
Originally Posted by thexter View Post
Has anyone installed an aftermarket keyless entry? The gen 2's have a single wire lock/unlock and I could sure use some guidance on system selection and installation direction.
There is a member on site...but I forget who...that did it. I also think they put up an extra unit for sale at the end of last year.
  #12 (permalink)
Old 03 May 2017, 10:41 am
LionPT,
I appreciate the info.
However, the only member I can find that was selling in the classifieds was jetmax for an RKE for a gen 1.
I need a keyless entry solution for the gen 2.
2006 PT Cruiser - Base model with AC
  #13 (permalink)
Old 03 May 2017, 10:55 am
LionPT's Avatar
LionPT,
There is a G2 around somewhere, maybe someone else will remember.
It was a Blue G2 with a video of his wife working the remote to show it off.
  #14 (permalink)
Old 03 May 2017, 11:00 am
I found that thread - i believe it was adding remote start to his existing keyless entry.
  #15 (permalink)
Old 03 May 2017, 04:23 pm
Having just finished my Body electric class where we talked about theft systems... I duno.
(quality education right there jk)
Technically if everything was there and the module was programmed correctly and the PCM was A-OK with the proper programming, It should work.
Without being intimately familiar with the Gen2's systems. There is certain information that can be generally applied. The PCM, Key, and SKREEM all exchange information to ensure proper theft system operation. You'd have to replace the SKREEM with a version that supports the keyless entry, so you'd have to go through with reprogramming the keys to the system again.
Also besides ensuring there are lock motors, and wireing. There might need to be a PCM reflash to enable keyless entry (Gen 2 problems).
If you would like me to seriously put some effort and time into researching this, PM me in 2 weeks when im done with finals and done working on my own car (lowering springs incoming).
myckee likes this.
03' Dream Cruiser Manual: 130k Stage 1, BOV, Koni Shocks, Eibach Springs/Sway Bars, TSW 18x8 Rims, Composite Manifold, 3inch Catless
Downpipe w/Cutout, Magnaflow Catback, Quaife LSD
04' GT Manual Purple PT Mileage: 95k (Died Spring 2018)
05' N/A Automatic Red PT Mileage:121k (Died summer 2017)
  #16 (permalink)
Old 04 May 2017, 06:33 am
Originally Posted by UnitD77 View Post
...You'd have to replace the SKREEM with a version that supports the keyless entry, so you'd have to go through with reprogramming the keys to the system again....
I think this is correct. If you look in the parts catalogue for an 06, and cross reference the sales codes, you can see that they have a few different part numbers for the skreem for immobilizer only, or immobilizer + keyless entry.
And not only would you have to program the vin and keys to the new module, like Rick posted earlier, if you installed a new skreem, you would have to turn on or off options based upon what the car has or not, probably in the TIPM/FCM as when it detects the new module, stuff will be activated, such as the tire pressure monitors etc.
It would be really cool to get a hold of a StarScan or whatever the new tool Chrysler uses now, and see just what you can turn on and off hidden inside the various modules.
rckstein likes this.
  #17 (permalink)
Old 04 May 2017, 09:28 pm
So I don't think a replacement SKREEM is the way to go. Don't want to break anything...
so now i need to find an aftermarket that works with the CAN BUS system...
BAH!
  #18 (permalink)
Old 04 May 2017, 09:38 pm
rckstein's Avatar
BAH!
The locks are electric from the inside, correct? If so, that means that all the lock actuators are in place.
It might be as simple as getting the correct SKREEM and keys, and some programming from a dealership? Have no idea what any of that would cost.
But you might have better luck and cheaper going through a stereo/alarm shop?
Tags
2006 pt cruiser, base model, gen 2, keyless entry
Keyless (i mean REALLY keyless) entry and start JooV General PT Cruiser Discussions 2 23 Dec 2012 04:38 pm
do i have keyless entry? alexsmith Sound and Security Forum 0 15 Aug 2012 07:05 pm
keyless entry help!! superbert1971 Tech & Performance Forum 4 28 May 2010 08:51 pm
keyless entry chintzgirl General PT Cruiser Discussions 3 29 May 2009 07:12 pm
Keyless entry? Blade General PT Cruiser Discussions 13 22 Mar 2004 05:52 pm
