A/C Issue/Won't kick on
Like Tree3Likes
  #11 (permalink)
Old 02 May 2018, 05:16 pm
Default Re: A/C Issue/Won't kick on
Originally Posted by Vengence View Post
No it does not.
I would suggest verifying that you manually test the radiator fan that both speeds are working. So many members have found out the hard way that one of the speeds was not working.
If radiator fans is working properly I would suggest checking to see if you have the TIPM. The A/C compressor relay is inside the TIPM and needs the signal before it turns on the A/C compressor.
  #12 (permalink)
Old 02 May 2018, 05:23 pm
No it does not.
  #13 (permalink)
Old 03 May 2018, 02:47 pm
Vengence's Avatar
Problem is solved. Freon level was....well....Non existent. There was no Freon in the tank at all. Bone dry. Cleaned out and filled up and all is working again.
My PT's-
2008 PT Cruiser LX Inferno Red
2003 PT Cruiser Base Woody Edition
  #14 (permalink)
Old 03 May 2018, 02:53 pm
Did they check for leaks? This is not good.
bob2006 likes this.
  #15 (permalink)
Old 03 May 2018, 11:44 pm
Vengence's Avatar
There were no major leaks. I was told that every A/C system has minor leaks from the pressure in the system. Also spoke with the dealer I bought it from (Which was also his personal vehicle) and he said it stopped working in 2015
end of summer and then he moved to NY in spring time. Doesn't get as hot in NY as it did in Tennessee so he never bothered to get it charged or fixed. So it's been inactive for 2 years almost. But, it works fine now and no leaks that I can see. Ran it all day. They also put Dye in the system so if it does leak more than normal they said they could see where its leaking from.
I did get him to reimburse me for half the cost of the recharge as its one thing he forgot to mention before I bought it. I didnt test it because it was mid winter when I bought it.
VsandFords likes this.
My PT's-
  #16 (permalink)
Old 04 May 2018, 01:01 am
My AC ran out of "Freon" once too.
Had it charged up.
No leak test.
Cost me $169
2 weeks later the AC stopped working....
Gotta fix that leak....
  #17 (permalink)
Old 04 May 2018, 02:58 am
Vengence's Avatar
So the all a/c systems have minor leaks due to pressure was bs then?
Got my oil change and chargeing ac for 150.
My PT's-
  #18 (permalink)
Old 04 May 2018, 09:35 am
It seems to me they agree that it is leaking but don't want to find the leak. The proper testing equipment is needed to trace the leak.
  #19 (permalink)
Old 04 May 2018, 09:37 am
A well maintained AC system should have no leaks.
Same as the AC in your house.
Now that you had yours filled lets hope that the leak you have is tiny and the Freon will last long enough to get you through the summer or maybe longer.
If the Freon lasts the summer and you don't mind the expense of refilling it once a year, then you're good to go.
If the Freon only lasts a week or two, then the leak has to be found and repaired.
  #20 (permalink)
Old 04 May 2018, 12:48 pm
Vengence's Avatar
Well, in any case I will be monitoring for leaks. It may or may not. If it does leak badly then ill get it fixed at some point. I havent seen any leaks on any lines or components. so. We'll see
My PT's-
lower kick panel dmcclanahan Interior Accessories Forum 6 16 Jul 2014 06:14 pm
kick plate? bryman Interior Accessories Forum 9 18 Mar 2012 09:39 pm
Turbo kick in vtmdsm27 Turbo Performance 11 26 Sep 2008 06:27 pm
kick panels for 2006 and up rte662006 Sound and Security Forum 1 15 Aug 2008 05:38 am
Qlogic Kick Panels anyone??? GTSteve Sound and Security Forum 4 25 Oct 2003 09:35 am
