Should motor move while idling?
Like Tree6Likes
  #11 (permalink)
Old 03 May 2019, 07:38 am
Default Re: Should motor move while idling?
Once again, pt06 has given great advice. I didn't know this and replaced the lower mount twice within 3 months because of it. That's what I got for not asking advice here first. That measurement is critical.
  #12 (permalink)
Old 03 May 2019, 09:07 am
Chuzz, this is why so many members depend on this website to keep their Pt Cruisers running properly. They know that members here give good advice..
chuzz likes this.
  #13 (permalink)
Old 03 May 2019, 12:12 pm
shelbyzman's Avatar
I measured and it is about 4mm off.
Is this video good to go by?
pt06 likes this.
2007 PT Cruiser GT 5-speed 17x8 Konig Inception wheels K&N style intake auto throttle body Spec D tail lights Blow off plate 10.2mm plug wires Cat-Back "DNA Motoring" exhaust w/ Thrush glasspack "blacked out" DIY ground effects added boost gauge (in place of analog clock)
  #14 (permalink)
Old 03 May 2019, 09:29 pm
shelbyzman's Avatar
I finished the job. Got it to the 4.72 in but it still has some engine movement. Not much but what is some movement normal?
  #15 (permalink)
Old 03 May 2019, 10:07 pm
I had about 5/8 of an inch movement in engine movement after replacing both torque upper and lower mounts shifting between reverse and drive. Never measure it idling but will measure it the morning.
  #16 (permalink)
Old 04 May 2019, 02:49 am
EXCELLENT video. A 6 inch long piece of wood [like a 2 x 4] can be used between the jack and the tranny flange [as shown in the video].
  #17 (permalink)
Old 04 May 2019, 08:08 am
loomex's Avatar
That last video is the single most useful video I have seen regarding the torque mount replacements.
"Christine", a 2002 (manufacture date 8/2001) base model, 2.4L 5-speed.
USAF 83-92, IRR 92-94, NV ANG 94-98, IRR 98-00
  #18 (permalink)
Old 07 May 2019, 01:29 pm
shelbyzman's Avatar
Hey, did you ever check to see what movement there is when idling? I just want to know if it is normal or if I need to figure out what is going on. I'm good on the 4.72" adjustment.
  #19 (permalink)
Old 08 May 2019, 07:34 am
A little movement is normal. As long as you have the correct measurement dialed in and everything is torqued to spec, you should be good to go.
  #20 (permalink)
Old 09 May 2019, 08:36 am
shelbyzman's Avatar
I little movement is normal. As long as you have the correct measurement dialed in and everything is torqued to spec, you should be good to go.
Good to know!
Have to move on red06limited General PT Cruiser Discussions 4 07 Apr 2019 04:25 pm
bad move mys Welcome New PT Cruiser Members 20 15 May 2016 10:35 am
Move car without key Djejdj Tech & Performance Forum 8 29 Mar 2016 09:35 pm
Fix the PT or Move On ? nepsi General PT Cruiser Discussions 12 18 Dec 2014 05:25 pm
won't move ptdman General PT Cruiser Discussions 4 14 Jun 2004 06:15 pm
