Adding power accessory plug to base model
Like Tree7Likes
  • 1 Post By ptal
  • 3 Post By sanatanadharma
  • 2 Post By sanatanadharma
  • 1 Post By ptal
Old 05 Oct 2020, 08:49 am
Default Adding power accessory plug to base model
I have acquired a 2004 base model PT. I would like to add the always on power accessory plug to the dash - on the row where the rear wipers & defrost switches are. The hole is already there, just need to pop the cover off and insert the plug.
The question is, before I tear everything apart, is the wiring and plug present for the outlet or will I need to run wires to do this? The plugs were present to add fog lights to the car.
I have pulled the cover off were the outlet goes but could not see any plug with the limited view through it.
Thanks
ptprice likes this.
Old 06 Oct 2020, 02:37 pm
Default Re: Adding power accessory plug to base model
I added the power outlet on my 2004 using an OEM outlet sourced from a salvage yard.
The dash wiring harness in my car had the necessary wiring and connector.
I do not remember if the fuse box was wired hot or not.
Sadly Covid ate all my notes, postings and pictures.
You can do it.
Old 06 Oct 2020, 08:52 pm
Old 12 Oct 2020, 08:38 am
The plug was there, the reason I could not see it through the hole where the accessory plug mounts was that it was folded back, zip-tied and taped to the wiring harness - probably to keep it from rattling. I ended up removing the radio to be able to get my hand in there and still see what I was doing to cut the zip tie and un-tape the wire. Other than that, it went smoothly, about half an hour overall from start to finish.
Thanks for everyone's help.
Handy_Cruiser likes this.
Base 2003 PT Cruiser adding sun roof gkusters Exterior Accessories Forum 3 18 May 2012 12:34 pm
Adding Power Mirrors to Base Model Superwoody Exterior Accessories Forum 7 18 Jan 2012 02:03 pm
Adding factory options to a Base cruiser. irvdog63 General PT Cruiser Discussions 9 16 Jun 2011 04:33 pm
Parting Out 2005 PT Cruiser base base model taftboys Classifieds: For Sale/Trade 9 07 Oct 2010 07:13 pm
Adding the leather seats to standard model matchboxtom Interior Accessories Forum 3 11 Nov 2003 08:48 pm
