PO201 thru 4 Codes
Old 20 Jul 2021, 05:15 am
Default PO201 thru 4 Codes
We've had lots of problems with keeping our latest PT running. This one is a 2006 and was showing PO201 thru PO204 codes indicating the fuel injectors needed serviced. Took the car in to the dealer yesterday for injector servicing and we still see the same codes this morning. What to do now? The PT starts and runs okay unless it is parked in the sun on a hot day ( this is in Florida) and is difficult to start or keep running. Excepting suggestions on what to do.
Old 20 Jul 2021, 06:49 pm
Default Re: PO201 thru 4 Codes
Did they check for proper fuel pressure at the fuel rail ?
Old 20 Jul 2021, 11:53 pm
What they claim they did: "Flush out fuel injectors, R/R throttle body, disassemble, clean reassemble with new gaskets, and make all necessary adjustments."
Old 21 Jul 2021, 03:51 am
The key here is the problem occurs on a hot day. Could be that the fuel pump is clogged or failing thus not providing enough fuel pressure and the hot weather compounds the problem. They need to check for proper fuel pressure.
po codes MRTN Western PT Forum 0 20 Mar 2013 12:33 pm
Dash codes--not the usual OBD codes--help! chitowncruiser General PT Cruiser Discussions 5 01 Mar 2013 11:56 pm
Codes, codes, codes... Desperately need engine light help... cdc3jj General PT Cruiser Discussions 9 01 Sep 2012 07:52 am
CODES codes codes... Anyone know what these codes may mean are wrong? rksnow1 Tech & Performance Forum 10 16 Jun 2012 11:06 pm
04 PT CODES?? NEW PC.. drumrooster Tech & Performance Forum 3 06 Aug 2011 04:35 pm
