22 Sep 2021, 02:29 pm
Re: Transmission fluid change. Should I do ?
Originally Posted by Macgyverman1123
Yours looks pretty red/clean, meaning that it is not burnt. If it was burnt, i'd tell you no way, but this looks perfect for changing! Change what you get out of the pan when you drop it. You'll also want to change the filter too, which is just inside the pan. It just snaps in. You might also want to throw a new pan gasket on. These are usually sold as a kit. Make sure you clean out the pan really good, and don't forget to check and make sure the magnets are in before you reinstall!
Thanks Macgyverman1123 and rcktpwrd for the replies. Yes, I'm planning drop the pan, replace filter and gasket, clean pan and magnet and put everything back on. Then refill with the same amount of fluid, using Valvoline ATF +4.
If everything goes well, I mean, no problem with the transmission, I'm planning to do an entire flush next year. For that I need to figure out where is the fluid return line to the transmission, so I can disconnect and catch the fluid out of it. Any idea which is the best point to disconnect the fluid return line ?
Lrbbs
