03 Dec 2021, 11:48 pm
Re: 2006 Cruiser leaking fuel near gas tank while the car is on.
Based purely on the info you listed, this is most likely one of the fuel lines. If it was just a cracked tank, it'd leak all the time. Same thing if it was the filler neck. When the fuel pump is running, there is actually a slight negative pressure in the tank, caused by the suction of the pump drawing fuel out of the tank and pushing it into the fuel system. I must admit I feel stupid not remembering if the Cruiser has a return fuel line or if it's returnless, but I believe it's returnless. I'd grab a new fuel line, or maybe even something generic, if you're feeling cheap. just remember to use actual fuel line, not just run-of-the-mill rubber.
-John P.
Go Canes! #TakeWarning
