Plastic PT Cruiser Intake Manifold Kit
  #21 (permalink)
Old 12 Jul 2005, 07:10 am
quote:Originally posted by Herschel
So, hyracer,
Any results you would care to share about the "plastic intake?" H.
Hi Herschel,
To be honest with you I can not tell any differance with the new manifold installed...but I'm already pushing Stage 2 HP levels anyway so 10 hp would not make as much a differance for me than someone at stock levels. I have found out however that now I can not change the #2 plug without either removing the plastic manifold or modifing the spark plug socket...
Hopefully someone ends up doing a back to back dyno test and can verify the results.
Deen
  #22 (permalink)
Old 12 Jul 2005, 07:39 am
I was told on a previous post that you can still change the plugs with the new manifold...is that true or not?
  #23 (permalink)
Old 26 Jul 2005, 03:50 pm
can i see photo of these new intake???
black 2004 limited edition with turbo lite stage 1 mopar bov and boost gauge. prototype power kit. k&n air filter s2 wga ebc greddy profec type 2 http://turbocruiser.monchar.com/
  #24 (permalink)
Old 26 Jul 2005, 04:55 pm
Send a message via AIM to dfunkdj
How much does the new plastic intake interfear with your #2 plug ?? Could you grind alittle of the intake seam away ?? Which socket are you using ?? I have the new manifold but havent got to put it on yet I am going to do a couple of things at the same time so i am getting all the stuff toghter.
Can you show a pic of how close it is ???
Don
<font color=\"orange\"><b>2003 Dream Cruiser II
Stage 1, Greddy blow off valve, AGP WGA, Custom open dual exhaust, Denso plugs, Xtremeboost upcharge pipe, AMX intake pipe, Ramair hoods hood, Apc ground effects kit, lowerd 3\", Turbo xs MBC, auto meter double gauge pod, and 2 more gauge mountd on sterring wheel {oil psi and temp, boost, water temp}
apc 2nd gen tail lights, more to come soon
Tampabay Pt Cruisers</b></font id=\"orange\">
  #25 (permalink)
Old 26 Jul 2005, 10:01 pm
Ok, here's one for you all. I have an 05' GT vert 5spd with the standard aluminum intake manifold, manufactured 5/04. I never had the car dynoed before messing with it so I don't know wether or not my car had anywhere close to the 220HP, 245LBS TQ stated by DC for the 05 GT engine. Did I get screwed on power because of the intake or did I get it and the power comes from PCM programming??? And if the power increase does come from the intake, can I replace mine and see stage 1 power increase?? TThrift says I can't order S1 for 04 with my VIN because of the programming even though I have the alum intake. Then why hasn't S1 been released for 05?? Or is the reason S1 isn't out yet is that some 05's have alum and the rest have plastic and it changes the power output with the S1 programming so some 05's in S1 mode would have more power than the cars with the alum intake and S1?? [xx(]
I don't know what's going on with the S1, but those at DC responsible for it should pull their heads out of their......
As far as the plugs go, just get the 5/8" spark plug socket with the universal joint on the connection end. It makes pulling the plugs from all the holes easier! And it costs about $6
05\' GT Convertible in Metallic Midnight Blue
Mods...
http://www.cardomain.com/memberpage/808143
Please see Forum Guidelines regarding signature image sizing.
  #26 (permalink)
Old 27 Jul 2005, 12:34 am
"but those at DC responsible for it should pull their heads out of their......"
Fat chance. We complained about stage 1 being so late and then the stage 2 fiasco and they didn' care at all. We are the red haired stepchild [xx(]
\'05 Stone White SRT4
\'04 Graphite PT Automatic
  #27 (permalink)
Old 27 Jul 2005, 02:58 am
Universal works great on #3 but can't help on #2..... problem is you can't even get the deepwell 5/8 plug socket into the hole unless you remove upper intake . This only applies to plastic intake . I'm just a bit hesitant to grind on new intake just yet. Removing to swap plugs isn't a real big deal especially if you've done plug changes on na's .
\'03 Electric Blue 5 speed GT, addco oversize sways,wildfire strut bar,color-matched rear muds,xenon sides/\"crusher\",mirrors,b&c pillars,both interior consoles,b&m sport shifter,autometer ultralite gauges,Mopar STG 1 ,booger shift bushings,mopar bov,AMX turbo up pipe,Prototype turbo ucp, 05 intake, map clamp
  #28 (permalink)
Old 27 Jul 2005, 05:53 pm
Again, DC, heads out please...
Hmmm, wonder what the dealerships are charging to change plugs out now during a routine tune up??? It's got to add a good $100 to the tab. Of course, I won't be paying...
Mods...
  #29 (permalink)
Old 27 Jul 2005, 06:49 pm
Not a big deal I agree, but it sure is nicer to be able to go down to the garage and check all the plugs in about 20 minutes without having to disasemble. What WERE they thinking.
  #30 (permalink)
Old 05 Aug 2005, 10:48 pm
They are the standard manifold in the 2005 Turbo HO car.
The simple fact of the matter is, aluminum and other metallic intakes increase heat conduction to the intake mass, and reduce the intake charge power potential.
I can get a part# off mine if you like.
Cheers,
Joe
05 GT HO, Stage 1, AGP WGA, Greddy BOV, 2 Stage WI, K&N CAI, Powder Coated Calipers, Cross-Drilled/Slotted Discs, Stainless Steel Flex Lines
PLASTIC GT MANIFOLD PROBLEMS? littleblueGT Turbo Performance 45 25 Nov 2011 12:10 pm
2004 Chrysler PT Dream Cruiser Series 3 skylight PT Cruiser News and Rumors 10 18 Jun 2009 08:57 am
question about plastic intake manifold steve smith Turbo Performance 32 22 Mar 2006 11:23 am
New 2005 Convertible PT Dream Cruiser skylight PT Cruiser News and Rumors 4 11 Jan 2005 06:12 pm
polished intake manifold(( IT"S HERE)) amx1397 Turbo Performance 25 07 Jan 2004 11:35 pm
