Turbo Timer
  #61 (permalink)
Old 24 Aug 2003, 10:12 am
Send a message via AIM to Mr.Blonde
Yes, i did get it from hector, and got the video. I have replaced my splice taps around 3 times already, so i am pretty sure the taps arent the problem. Now I think that the problem might be in the Blitz ground wire. Where did you put yours? I put mine on the screw holding the fuse box.
Now with stage 1
Just a GT... Thats tearin\' arse on the driveway.
http://www.cardomain.com/id/themanfrmokinawa
14.626 @ 94.74
stage 0 , intake and exhaust only.
  #62 (permalink)
Old 24 Aug 2003, 02:45 pm
I put mine in the same place. If I remember I had 2 black wires and one purple. I took all 3 to the same ground.
Don
2003 PT GT
  #63 (permalink)
Old 24 Aug 2003, 03:26 pm
Me too, I just took the purple , and cut the outside of it, wrapped it around the screw, then put the other 2 under the screw, then screwed the screw in. I used the top screw. Did i do anything wrong? I have never done any wireing so I could have easily made a mistake.
Now with stage 1
14.626 @ 94.74
  #64 (permalink)
Old 24 Aug 2003, 05:01 pm
I have a blitz turbo timer from Exhaust Depot. I watched the vid, and can't get it.
Which blue wire did you guys use, the skinny "carolina blue"? Or the thicker gage blue without the black stripe?
Do i need the purple? I didnt hook that one up! I thought it was only for the ebrake. I'll try that now.
Black 03 GT - silencers removed. PT Cruiser 3BL. Much more to come
  #65 (permalink)
Old 24 Aug 2003, 05:28 pm
sfhickey, The purple wire is a must. It is a safety that can be connected to a switch, nornally the 5 spd to make sure it is in neutral. If you do not use it you must ground it. It has been a while but I beleive it was a light blue wire with no stripe.
Alan, that is what I did. The only other thing I can think of is that the TT may not be set in auto mode. I normally have it set on the screen that shows vac and boost. I have hit the other button by mistake and taken it out of auto mode. It must be in auto mode to keep the car running.
Don
2003 PT GT
  #66 (permalink)
Old 24 Aug 2003, 06:33 pm
this is the one from the neon
"thick sky blue wire"
the pic i have has no stripes on it.
  #67 (permalink)
Old 24 Aug 2003, 09:45 pm
There are the two wires, the skinny carolina blue, that is not close to the rest of the wires, then there is the thicker blue. I originally used the skinny blue, but Hector said that all of the wires are close to each other.
Now with stage 1
14.626 @ 94.74
FS: Blitz Turbo Timer cruizer_style Classifieds: For Sale/Trade 15 03 May 2005 12:41 am
Turbo Timer .... onedivinehammer Turbo Performance 19 08 Aug 2003 05:59 pm
Chrysler to Offer New Cheaper GT Turbo skylight PT Cruiser News and Rumors 19 12 Jun 2003 02:04 pm
Blitz Dual Turbo Timer, anyone? magictrickboy71 Turbo Performance 10 01 May 2003 05:10 pm
Turbo Timer Installed Exhaust Depot Turbo Performance 11 13 Apr 2003 12:12 am
